I have a failed Insteon 2466DW wall dimmer module. With no prior problems, today it was full bright and air gap reseting did not fix it, it stays ON unless air gap is pulled out.
I have a replacement module ready to be installed. What is the best most straightforward sequence to replace the module as far as the Insteon plugin is concerned?
