New HS4 user (zero previous HS experience). Trying to add MS's Insteon plugin...
In the "getting started" guide it says:
4. HS2: Restart HS and goto the HS setup/interface page, and Enable the IO Interface. If you use X10, enable that interface as well.
HS3: Restart HS, go to the Manage/Plugin page and enable the plugin. Enable X10 on the plugin config page if necessary.
Does anyone know where to enable the IO interface in HS4?
