I have a toggle Insteon switch that I deleted. I need to add it back in but it doesn't show up in the device listing. How can I make sure it's deleted to add again or reinstate the one I had?
Re-adding switch
if you deleted it from hs, then just restart the plugin, and the plugin will create a new hs device (it will have a new dev ref #) so you will need to update your events.
if you deleted it from the plugin, the just register it again.Mark
HS3 Pro 3.0.0.534
when you attempt to add it back to the plugin, what happens? enable detailed logging on the plugin config page, and post the hs log snippet of the registration processMark
HS3 Pro 3.0.0.534
the switch is responding (so that is good), but isn't responding as expected. can you do a manual factory reset on the switch and try again. the reset process is outlined in the switch manualMark
HS3 Pro 3.0.0.534
can you post a pic of the links for the device?Mark
HS3 Pro 3.0.0.534
find the device under Manage Devices, then you will see the list of links specific to the deviceMark
HS3 Pro 3.0.0.534
click the yellow link icon to get you to the links for the specific device. i'm looking for something like this
Mark
HS3 Pro 3.0.0.534
but post the entire pageMark
HS3 Pro 3.0.0.534
if you tap added the device you to run the 'program device for homeseer'
click the Return to Device page button , the run the above routine. there should be a few links added.Mark
HS3 Pro 3.0.0.534
