i/o linc 2540 not operational
    i have an i/o linc device which I use to control my house water supply.. it is connect thru ifttt to some water sensors at my water heater and washing machine.
    with the builtin insteon plugin i get a device I can operate from the HS devices screen.. I see both the sensor and the relay in the advanced config for this device
    is there some config i can do to enable the on/off control of this device from the hs screen? i can do it thru the insteon app
    Insteon Device ID: 4A.A0.EA
    Device Name: water vavle
    Device Location:garage
    Floor: main
    Device Type: I/O Linc
    Firmware Version: 41
    Comm Reliability: (Not enough data)
    Polling Interval (Minutes, 0=None):
    Sync linked responder devices
    Automatically shut Off HS device when in Momentary Mode
    Disable relay polling
    I/O Linc Channels
    Channel Custom Device Name
    1: (Input Sensor)
    2: (Output Relay)
    Device Link Table
    Link #1 Input Sensor controls Unregistered Device (39.FA.E7)
    Link #6 Input Sensor has local control reporting to HomeSeer
    Link #8 Input Sensor is controlled by HomeSeer using RF PLM Group #0 (i2CS Registration Link) - On Level : On
    Link #7 Input Sensor is controlled by HomeSeer using RF PLM Group #1 (Button Control Group) - On Level : Off
    Link #5 Input Sensor is controlled by HomeSeer using RF PLM Group #1 (Button Control Group) - On Level : On
    Link #3 Input Sensor is controlled by Unregistered Device Group 0 (39.FA.E7) - On Level : Off
    Link #2 Input Sensor is controlled by Unregistered Device Group 1 (39.FA.E7) - On Level : Off
    Link #4 Input Sensor is controlled by Unregistered Device Group 13 (39.FA.E7) - On Level : On
    Warning: This Insteon device controls or is controlled by devices you have not yet registered with the plug-in. HomeSeer may not be aware of any control commands that might come from the unregistered device. Please add the unknown device to your system if possible.
    Custom Settings (* indicates default setting)
    Closure Time Clear Monentary 0.1 secs 0.2 secs 0.3 secs 0.4 secs 0.5 secs 0.6 secs 0.7 secs 0.8 secs 0.9 secs 1.0 secs 1.1 secs 1.2 secs 1.3 secs 1.4 secs 1.5 secs 1.6 secs 1.7 secs 1.8 secs 1.9 secs 2.0 secs 2.1 secs 2.2 secs 2.3 secs 2.4 secs 2.5 secs 2.6 secs 2.7 secs 2.8 secs 2.9 secs 3.0 secs 3.1 secs 3.2 secs 3.3 secs 3.4 secs 3.5 secs 3.6 secs 3.7 secs 3.8 secs 3.9 secs 4.0 secs 4.1 secs 4.2 secs 4.3 secs 4.4 secs 4.5 secs 4.6 secs 4.7 secs 4.8 secs 4.9 secs 5.0 secs 5.1 secs 5.2 secs 5.3 secs 5.4 secs 5.5 secs 5.6 secs 5.7 secs 5.8 secs 5.9 secs 6.0 secs 6.1 secs 6.2 secs 6.3 secs 6.4 secs 6.5 secs 6.6 secs 6.7 secs 6.8 secs 6.9 secs 7.0 secs 7.1 secs 7.2 secs 7.3 secs 7.4 secs 7.5 secs 7.6 secs 7.7 secs 7.8 secs 7.9 secs 8.0 secs 8.1 secs 8.2 secs 8.3 secs 8.4 secs 8.5 secs 8.6 secs 8.7 secs 8.8 secs 8.9 secs 9.0 secs 9.1 secs 9.2 secs 9.3 secs 9.4 secs 9.5 secs 9.6 secs 9.7 secs 9.8 secs 9.9 secs 10.0 secs 10.1 secs 10.2 secs 10.3 secs 10.4 secs 10.5 secs 10.6 secs 10.7 secs 10.8 secs 10.9 secs 11.0 secs 11.1 secs 11.2 secs 11.3 secs 11.4 secs 11.5 secs 11.6 secs 11.7 secs 11.8 secs 11.9 secs 12.0 secs 12.1 secs 12.2 secs 12.3 secs 12.4 secs 12.5 secs 12.6 secs 12.7 secs 12.8 secs 12.9 secs 13.0 secs 13.1 secs 13.2 secs 13.3 secs 13.4 secs 13.5 secs 13.6 secs 13.7 secs 13.8 secs 13.9 secs 14.0 secs 14.1 secs 14.2 secs 14.3 secs 14.4 secs 14.5 secs 14.6 secs 14.7 secs 14.8 secs 14.9 secs 15.0 secs 15.1 secs 15.2 secs 15.3 secs 15.4 secs 15.5 secs 15.6 secs 15.7 secs 15.8 secs 15.9 secs 16.0 secs 16.1 secs 16.2 secs 16.3 secs 16.4 secs 16.5 secs 16.6 secs 16.7 secs 16.8 secs 16.9 secs 17.0 secs 17.1 secs 17.2 secs 17.3 secs 17.4 secs 17.5 secs 17.6 secs 17.7 secs 17.8 secs 17.9 secs 18.0 secs 18.1 secs 18.2 secs 18.3 secs 18.4 secs 18.5 secs 18.6 secs 18.7 secs 18.8 secs 18.9 secs 19.0 secs 19.1 secs 19.2 secs 19.3 secs 19.4 secs 19.5 secs 19.6 secs 19.7 secs 19.8 secs 19.9 secs 20.0 secs 20.1 secs 20.2 secs 20.3 secs 20.4 secs 20.5 secs 20.6 secs 20.7 secs 20.8 secs 20.9 secs 21.0 secs 21.1 secs 21.2 secs 21.3 secs 21.4 secs 21.5 secs 21.6 secs 21.7 secs 21.8 secs 21.9 secs 22.0 secs 22.1 secs 22.2 secs 22.3 secs 22.4 secs 22.5 secs 22.6 secs 22.7 secs 22.8 secs 22.9 secs 23.0 secs 23.1 secs 23.2 secs 23.3 secs 23.4 secs 23.5 secs 23.6 secs 23.7 secs 23.8 secs 23.9 secs 24.0 secs 24.1 secs 24.2 secs 24.3 secs 24.4 secs 24.5 secs 24.6 secs 24.7 secs 24.8 secs 24.9 secs 25.0 secs 25.1 secs 25.2 secs 25.3 secs 25.4 secs 25.5 secs
    Operating Flags (* indicates default setting)
    I/O Linc Mode Continuous* Momentary A Momentary B Momentary C
    Relay set via Sensor Input Disabled* Enabled
    Send On Cmd When Closed* When Opened
    LED On* Off
    Beep with Set Btn Off* On
    device list
      there should be on/off buttons on the relay device. and there should be a hs device for the input sensor. you may need to delete these hs devices and restart the plugin so they can be recreated
      Mark
      HS3 Pro 3.0.0.534
        but there is no relay device in the device list, that was my point
          now suddenly the relay device is there.. a day later... weird..
            thanks for reporting back
            Mark
            HS3 Pro 3.0.0.534
