Page refresh issue with my HS3 insteon plugin running on HS4...solved
    when registering, or programming any insteon device, the status page is not refreshing even though the plugin is working.
    HS4 broken something in the HS3 API. I have an email into HST on this issue.
    please hold off starting any more threads on this issue.
    As a workaround, click Home, and then return to the plugin config page from the Plugin menu
    Mark
    HS3 Pro 3.0.0.534
    HST has fixed the refresh problem
    the fix will be in build 4.1.7.0 which will be posted today (9/17).
    Mark
    HS3 Pro 3.0.0.534
      Please reply if the latest version of HS4 fixes the page refresh issue for you
      Mark
      HS3 Pro 3.0.0.534
        How do I upgrade it? I went to the Plugin's page and no little cloud there?
          in order to upgradeHS4, shut it down, and restart it. the update will be presented
          Mark
          HS3 Pro 3.0.0.534
            I disabled the upgrade check in HS3 because is seemed to prevent automatic startup when an update was available. Is there still an EXE you can run with HS4 to check for updates?
            HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
              I have noticed this same behavior in HS3, when in zwave management
              with the same workaround
              click Home, and then return to the zwave management page, maybe one then once.
              This is using chrome browser. If I hit refresh it creates problems....
                I restarted twice.....still 3.something....
                  what version number are you referring to when you say 3.somthing?
                  Mark
                  HS3 Pro 3.0.0.534
                    Upgraded to 4.1.7.0 on a windows install and fixed page refresh issue.
                    Jim
                      3.0.7.1 I'm doing something wrong.
                        You need to update hs4. Not the plugin. Restart HomeSeer
                        Mark
                        HS3 Pro 3.0.0.534
                          The upgrade to 4.1.7.0 on my Pi4 running HS4 Standard fixed the page refresh issue for me.
                            the refresh is now working - even "down under"....
