Mark, I have a Synchrolinc for my sump pump and events to detect the running time and warn of a fault if it runs too long, too short, or not for an extended period. The events are triggered by special Insteon triggers "Sends On Command" and "Sends Off Command". On occasion I receive the On but not the Off (my only device that has poor comm), so I have a check event that detects when the pump has been running too long and polls the device to provoke the OFF response. It has never worked right and it just dawned on me that the Insteon Poll must be updating the device status to OFF, but is not firing the associated "Sends Off Command" trigger.
This would be an issue for any event that is written to use any of your great Special Insteon triggers because it would not fire as the result of a poll. If using the "Changes and Becomes" trigger it would fire. I also use the Poll All Devices command after a power failure to bring things up to date. I assume those poll results would not trigger any of the Special Insteon triggers either. Could that be fixed?
