I did a 100% clean installation yesterday, reinstalling HS4 and adding my devices, starting from scratch. I'm getting the error "Please check the interface and enter the Interface Port information on the Config page and restart HS" which goes away when I restart the plugin. I'm set to the standard 3 Maximum Hops, 5 Command Retries and 3 sec response timeout. Does anyone have any thoughts as to how to resolve the issue?
Error "Please check the interface and enter the Interface Port information..."
please post a pic of the plugin config pageMark
HS3 Pro 3.0.0.534
if you access the url via browser, can you login with the credentials you listedMark
HS3 Pro 3.0.0.534
you should be using the credentials on the bottom of the hubMark
HS3 Pro 3.0.0.534
Mark,
Last night (very late) I received the following new error. "WARNING: Please check the Interface and enter the Interface Port information on the Config page and restart HS."
I checked the settings in the Insteon management app under 'House' in Settings and the port is 25105 and the IP is correct.
what platform are you running hs on? what version of the plugin?
are you config settings gone, or did the hub just stop responding?Mark
HS3 Pro 3.0.0.534
can you post a log snippet around the time things stop workingMark
HS3 Pro 3.0.0.534
Here’s a chunk...
AM
Legacy-Plugin
Insteon
..Could not contact Interface on 192.168.1.2:25105
9/1/2020 7:05:24 AM
Legacy-Plugin
Insteon
The Interface has failed to transmit the last 10 commands.
9/1/2020 7:05:11 AM
Legacy-Plugin
Insteon
Attempting to restart the port and Interface...
9/1/2020 7:05:11 AM
Legacy-Plugin
Insteon
9/1/2020 7:05:11 AM
Legacy-Plugin
Insteon
9/1/2020 7:04:56 AM
Legacy-Plugin
Insteon
9/1/2020 7:04:55 AM
Legacy-Plugin
Insteon
Warning! Communications lost. Attempting to restart the port...
9/1/2020 7:04:55 AM
Legacy-Plugin
Insteon
Interface_TrapError called from SendHex
9/1/2020 7:04:55 AM
Legacy-Plugin
Insteon
The Hub has failed to transmit the last 10 commands.
9/1/2020 5:43:17 AM
Legacy-Plugin
Insteon
Received House Deck Lights (41.F5.27) Go OFF
9/1/2020 5:06:00 AM
HomeSeer
Energy DB Info
All energy database compacting routines completed.
9/1/2020 5:06:00 AM
HomeSeer
Energy DB Info
No Records. Vacuuming database to condense.
9/1/2020 5:06:00 AM
HomeSeer
Energy DB Info
Energy database compaction initiated.
9/1/2020 5:05:20 AM
Legacy-Plugin
Insteon
Interface successfully restarted.
9/1/2020 5:05:16 AM
Legacy-Plugin
Insteon
Hub contacted on 192.168.1.2:25105 with an Insteon address of 4A.91.4D and firmware version A5
9/1/2020 5:05:03 AM
Legacy-Plugin
Insteon
9/1/2020 5:05:03 AM
Legacy-Plugin
Insteon
9/1/2020 5:04:49 AM
Legacy-Plugin
Insteon
9/1/2020 5:04:48 AM
Legacy-Plugin
Insteon
9/1/2020 5:04:48 AM
Legacy-Plugin
Insteon
9/1/2020 5:04:48 AM
Legacy-Plugin
Insteon
9/1/2020 4:42:12 AM
HomeSeer
Info
System connected to MyHS Service successfully with license ID 670068.
9/1/2020 4:42:12 AM
HomeSeer
Info
System connected to MyHS Service, waiting for acknowledge...
9/1/2020 4:42:01 AM
HomeSeer
Warning
Have not heard from MyHS in over 3 minutes, disconnecting for re-connection.
9/1/2020 4:38:22 AM
HomeSeer
Info
9/1/2020 4:38:22 AM
HomeSeer
Info
9/1/2020 4:34:53 AM
HomeSeer
Warning
MyHS could not connect to server: No such host is known
9/1/2020 4:34:48 AM
Ecobee
Error
An error occurred while sending the request.
9/1/2020 4:34:48 AM
Ecobee
Error
9/1/2020 4:34:48 AM
Ecobee
Error
9/1/2020 4:34:42 AM
HomeSeer
Warning
Error serializing myhs data: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
9/1/2020 4:05:03 AM
Legacy-Plugin
Insteon
9/1/2020 4:04:59 AM
Legacy-Plugin
Insteon
9/1/2020 4:04:48 AM
Legacy-Plugin
Insteon
9/1/2020 4:04:46 AM
Legacy-Plugin
Insteon
9/1/2020 4:04:46 AM
Legacy-Plugin
Insteon
9/1/2020 4:04:46 AM
Legacy-Plugin
Insteon
9/1/2020 3:00:02 AM
HomeSeer
Info
9/1/2020 3:00:02 AM
HomeSeer
Info
9/1/2020 3:00:02 AM
HomeSeer
Info
Starting the MyHS Service...
9/1/2020 3:00:00 AM
HomeSeer
Info
Stopping the MyHS Service...
9/1/2020 2:22:51 AM
HomeSeer
Device Control
Device: House Couch Light to Off (0) by/from: CAPI Control Handler
9/1/2020 2:19:41 AM
HomeSeer
Device Control
Device: House Fireplace Light to Off (0) by/from: CAPI Control Handler
9/1/2020 2:05:24 AM
HomeSeer
Device Control
Device: House Fireplace Light to On (100) by/from: CAPI Control Handler
9/1/2020 2:05:05 AM
HomeSeer
Device Control
Device: House Garage Lights Outside to Off (0)
9/1/2020 2:05:05 AM
HomeSeer
Device Control
Device: House Front Door Lights to Off (0)
9/1/2020 2:05:05 AM
HomeSeer
Device Control
Device: House Front Porch to Off (0)
9/1/2020 2:05:05 AM
HomeSeer
Event
Event Trigger "Outside Outside Lights Off"
9/1/2020 2:04:48 AM
HomeSeer
Device Control
can you post a pic of the Advanced tab from within the plugin configuration pagesMark
HS3 Pro 3.0.0.534
can you tell me about the network setup? how is the hub connected to the network?Mark
HS3 Pro 3.0.0.534
