Upgrading to HS4. Installed the Insteon plugin, followed the guidance on the sticky page. I have tried both COM1 and COM2 (per Device Manager - the only 2 COM ports). I continue to get the error message "WARNING: Please check the Interface and enter the Interface Port information on the configuration page and restart the plugin." Sorry, I'm stuck. Any suggestions to get past this current hurdle?
HS4 Upgrade - Plugin Configuration (2413U)
are you using windows or linux?
is the 2413u new to the OS? you may need to installed the ftdi drivers for windows
you can identify which port to use by unplugging and plugging in the PLM and watching which port is added under the device manager Ports
the plm port should say USB Serial Port.
can you post a pic of the Ports in device manager with the plm plugged in.
hover you mouse of the blue ? to see the ports that the plugin foundMark
HS3 Pro 3.0.0.534
what ports are listed when you hover on the blue ? after "interface port"Mark
HS3 Pro 3.0.0.534
Originally posted by dmusel View PostI see that you said you thought the 2413U isn't very reliable. In your opinion is the serial or the Insteon Hub better? Curious what you think. Thanks again for your assist.
thanks for reporting backMark
HS3 Pro 3.0.0.534
