Hi Mark,
I am in the process of swapping out my hub with a usb plm and i am encountering an issue adding an old KeypadLinc Dimmer v2. I wanted to do a clean switch over so I so i reset everything. When i add the keypadlinc i am missing options it sees it only as a 6 button model and i have no option to set it to 8 key mod.
My logs don't say much
This was working fine but it was in the old database for years and this is the first time i removed and readded in at least 4 years. I olnly get on level and ramp rate as options. I am on the latest beta of your plugin and current release of hs4
Aaron
10/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A21F2B9273FF1F0810/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A21E2B9273FF1F0610/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A21D2B9273FF1F0510/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A21C2B9273FF1F0410/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A21B2B9273FF1F0310/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A21A2B9273FF1F0110/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to A2FE2B9273FF1F0110/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to E2082B9273FF1F0810/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to E2062B9273FF1F0610/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to E2052B9273FF1F0510/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to E2042B9273FF1F0410/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to E2032B9273FF1F0310/6/2020 9:17:50 PMLegacy-Plugin Insteon Program Remote Record not needed for 05.7E.2B to E2012B9273FF1F0110/6/2020 9:16:46 PMHomeSeer Error Saving database: Value cannot be null. Parameter name: collection10/6/2020 9:15:53 PMLegacy-Plugin Insteon Found unused link #31 in our address space, assigning for use.10/6/2020 9:15:52 PMLegacy-Plugin Insteon Found unused link #30 in our address space, assigning for use.10/6/2020 9:15:52 PMLegacy-Plugin Insteon Found unused link #29 in our address space, assigning for use.10/6/2020 9:15:51 PMLegacy-Plugin Insteon Found unused link #28 in our address space, assigning for use.10/6/2020 9:15:51 PMLegacy-Plugin Insteon Found unused link #27 in our address space, assigning for use.10/6/2020 9:15:50 PMLegacy-Plugin Insteon Found unused link #26 in our address space, assigning for use.10/6/2020 9:14:45 PMHomeSeer Error Saving database: Value cannot be null. Parameter name: collection10/6/2020 9:13:44 PMLegacy-Plugin Insteon Deleting HS device: Living Room Front Porch - Button Off (ref=54)10/6/2020 9:13:44 PMLegacy-Plugin Insteon Deleting HS device: Living Room Front Porch - Button D (ref=53)10/6/2020 9:13:43 PMLegacy-Plugin Insteon Deleting HS device: Living Room Front Porch - Button C (ref=52)10/6/2020 9:13:43 PMLegacy-Plugin Insteon Deleting HS device: Living Room Front Porch - Button B (ref=51)10/6/2020 9:13:43 PMLegacy-Plugin Insteon Deleting HS device: Living Room Front Porch - Button A (ref=50)10/6/2020 9:13:43 PMLegacy-Plugin Insteon Deleting HS device: Living Room Front Porch - Button On/Load (ref=49)10/6/2020 9:13:42 PMLegacy-Plugin Insteon Deleting the device Living Room Front Porch (05.7E.2B) links from the RF PLM
Aaron
