I hope you will indulge a newbie's question. I am trying to figure out how to configure a KPL and FanLinc to work via HomeSeer. I am running HS4 v4.1.8.0 and the insteon plugin v.3.0.7.1 . I have these devices set up and working correctly in the Insteon app. I've tried adding these devices to HS via the plugin in various configurations - Just the KLP; just the FanLinc; both. With sync linked responder devices checked an unchecked. The best result I have achieved was a HS "device" that would allow me to control the fan. I have been unable to configure things to show, let alone control, the light. I've tried to research the forum, but most posts appear to address implementations that are far more complex than what I am trying to accomplish. I'm hoping someone can provide a straight forward, step-by-step, list to configure these devices so they will work in HS. I have noted that the plugin "reports" a number of "unregistered Insteon addresses." Three for the FanLinc and two for the Keypad. I have no idea what this is telling me... I appreciate any and all help folks my be able to provide... Best regards - J
Configure FanLinc and Keypad
here are a few related thread
basically, if you are using a 6 btn kpl as the controller, you will create a radio group with btns a-d to represent high, med, low, off, for the fan speed. create links from each btn to the fanlinc fan device with the approp fan speed setting. the kpl on/off btns will controll the fanlinc light.
https://forums.homeseer.com/forum/li...eypadlinc-pair
https://forums.homeseer.com/forum/li...rol-and-events
Mark
HS3 Pro 3.0.0.534
Thanks for the quick response! but this is where my "newbie" status comes in to play. Yes, I am using a 6 btn kpl as the controller. Where in the plugin interface do I go to create the radio group? I know nothing about this plugin and need to start from scratch. The "?" help icons do not seem to work so I have no additional information to draw from. When I look at the device link table for the kpl, I see (channels) 1 (Button On/Load), 2 (Button A), 3 Button B), 3 (Button C). So is On/Load actually button D? On this page, I can only set/change button groups for buttons A and B. I do not have this option for On/Load or C. Where/how do I configure the on/off buttons for the light? This is the function I have been unable to create at all. I have been able to create a HS device to control the fan just by adding the FanLinc, but using the HS device to change the fan speed does not change the kpl lights. Help!...
from your screen shot, you need to change the button mode of the 4 buttons to radio group, then save the changes. the plugin will program the kpl.
create a link from the kpl On btn to the fanlinc light device
Mark
HS3 Pro 3.0.0.534
My options for "Button Mode" are "Toggle" or "Non-Toggle On." I have options for "Radio Group" 1 and "Radio Group 2" under "Button Groups." However, I only have these options for Buttons A and B (as reflected in the screen shot). I've also noted that if I change any of these options, I do not get a "Save" Button, I only have the option to "Return to Device List."
Mark
HS3 Pro 3.0.0.534
if you aren't seeing the same thing, can you copy the [device x] section from the config\insteon.ini file for the kpl in question and post it hereMark
HS3 Pro 3.0.0.534
