USB PLM fails, New PLM doesn't reprogram its database links
This topic is closed.
    Twice now I have had my PLM fail and when I installed a new one it doesn't reprogram my links. This is a big deal since I have over 100 devices. I just installed my 2nd PLM, can you help me reinstall my links without starting over. When I use the "Program Replacement/Swapped Interface" it reports
    The swap routine finished.
    Devices successfully reprogrammed: 0
    Devices did not need to be reprogrammed: 0
    Devices not reprogrammed: 0
    What can I do?
    Rick J
    make sure you are entering the correct insteon id. it wants the old id, not the new one
    Mark
    HS3 Pro 4.2.19.5
      Thank you, I did enter the old PLM address
        are links in the existing devices showing an unregistered insteon id of the old plm?
        can you post some pics of the config page, and some links from a few devices?
        Mark
        HS3 Pro 4.2.19.5
          Forgive me but maybe I'm not sure where to look but the new PLM and my homeseer software show zero links
          Here is the screen shot:
            The 2nd PLM stopped working after working normally for months and the interface port was blank on the above screen shot. I hadn't changed it and didn't remember what if anything I had in their for a USB PLM. I tried USB and other com ports 1, 2 an 3 but had no response with the PLM. I talked to Smarthome tech thinking the PLM had died and they had me reset it. This didn't help. I bought a new PLM and had the same no response error from the new one when I installed it. I tried all the com ports just for drill and it worked on com 6 which I'm sure I never had used.
              Is com 6 normal for a USB PLM?
                there is no normal com port for a plm. its based on your windows setup and other virtual ports that are already in use.
                if you have it working on COM6, that's fine
                can you take a screen shot of the links of one of your devices.find one of the devices in the manage device page
                Mark
                HS3 Pro 4.2.19.5
                    There are no devices, I had over 100 before
                      if all your devices are missing, you need to restore two files. first shutdown hs
                      restore a data\homeseer.hsd and an config\insteon.ini file from the same backup
                      the plm swap shouldn't have caused anything related to the devices; something else must have happened
                      Mark
                      HS3 Pro 4.2.19.5
                        I've shutdown hs but I can't find these files. I am running a remote desktop to my hs pro that is in another room, if that maters
                          I'm using file explorer on the hs computer
                            do you make backups of your hs server?
                            Mark
                            HS3 Pro 4.2.19.5
                              No, didn't know I needed to. I will now. Any other options I can try to recover my links without having to reenter them all again?
