HS4 stopped communicating with the insteon hub
    Hi Mark
    I started a new topic about it but nobody responded.
    How do I change from a insteon hub to a 2413U?I ran your swap interface but it asks for the old interface ID.How do I input the new interface ID?
      i posted this to the visitor message you left earlier. did you not get it?
      you need to enter the insteon id for the hub. the plugin knows what the new plm id is. you can run the swap routine several times. it will only update devices with the old ID
      Mark
      HS3 Pro 3.0.0.534
        I didn't get the visit message.I ran the swap interface using the current insteon hub ID.I got the prompt that all 45 devices have been successfully reprogrammed.Pulling the ethernet cable from my hub to test if all runs through the new PLM but it doesn't.How di I test if your plugin sees the new insteon PLM?is there a com port I need to enter somewhere?
          you need to change the config page and enter the correct COM port and then restart the plugin
          hover over the blue ? to see a list of option ports if you dont know whiich one
          Mark
          HS3 Pro 3.0.0.534
            It says com1 and com2 but nothing works.do I need to configure those ports in windows10?
              please start a new thread in the forum. we are way off topic for this thread
              Mark
              HS3 Pro 3.0.0.534
                hound a earlier post that I have to install :
                3. For Windows, If you have a 2412u, 2413u or 2448A7T, then download and install the latest ftdi chipset drivers. this driver will provide the virtual com port that the plugin needs. This is probably not necessary for Homeseer appliances, or other Linux installations.
                http://www.ftdichip.com/Drivers/VCP.htm
                installation instructions: http://www.ftdichip.com/Support/Docu...tallGuides.htm
                Is that still the case for the 2413U
                  if you are using window install the drivers, and see the device manager to determine the com port to use in the plugin. my guess is COM3 after you install the driers
                  Mark
                  HS3 Pro 3.0.0.534
