it looks like the plugin stops talking to the insteon hub when I get the question marks.Insteon hub is showing a green light.when I disable and re-enable the plugin it starts communicating again.see log.
HS4 stopped communicating with the insteon hub
This topic is closed.
can you run the reset and reprogram function from the plugin config page?Mark
HS3 Pro 4.2.19.5
are you using the insteon app as well? if not, please uncheck the 'process ACKs' option from the advanced tab. also for now, display polling from the config page
please enabled detailed logging, control one device from the hs ui, and then post the log snippet of that transaction.Mark
HS3 Pro 4.2.19.5
OK did that log is attached.After not playing with it for an hour i checked the installed plugin page and it had: unable to communicate with hub.after disabling and reenabling the plugin all will be fine for 30 minutes.Same username and password.somehow the plugin disconnects from the insteon hub. looked at the http://connect.insteon.com/getinfo.asp page and the hub is online and stable.Attached Files
(1) can you tell me about the network setup between the hometroller pro HS4 and the hub? how are they connected?
(2) what is the insteon id of your hub?
also, on the config page, change the Maximum Hops to 4
Mark
HS3 Pro 4.2.19.5
both are connected to a netgear switch.Running diagnostics on the switch show no errors.insteon hub ID 50.B7.75 Home seer and insteon have both static IPs.I've fired up the Linksys troller PI again and it's rock solid.Running the same versions on HS4 and your plugin on the Linux as on the windows system.I also have insteon motion sensors they work fine on the linux system and are not working properly on the windows HS4.
there is no difference in the plugin code regarding linux vs windows when it comes to the hub. the difference is windows runs .Net and linux runs Mono.
is the plugin generating any Insteon Error Report.log files in the hs config folder? if so, can you post the latest.
could you try plugging in the hub to a different circuit just to rule out noise from the new hometroller. just use a long extension cord from the hub to a different outletMark
HS3 Pro 4.2.19.5
its a subfolder within the homeseer root folderMark
HS3 Pro 4.2.19.5
