Ok not expecting any magical pixy dust. Slowly many of my Insteon devices are starting to act up. I am confident that this is not a driver issue but posting here as I am sure others have run into this. Many of my Insteon devices are generation 2 or 3 and essentially the lightbar will flicker up and then go off. The load usually may ramp up as well, but many times after a while the load doesn't even turn on anymore. Hardware reset and other methods including disconnecting the load doesn't change anything.
I am guessing that it is the power supply circuitry inside of the switchlinc and keypadlinc.
Anyone (I am sure) have had these experiences? Any resolution?
I really don't want to buy new Insteon equipment. If there is a way to fix it then I may consider it.
