i did not remove it from the plugin. what version of HS and the plugin are you running? with detailed logging enable, can you post a log snippet of the registration process so i can see what's going on
Reason: i did not remove it from the plugin
Mark
HS3 Pro 3.0.0.534 Hardware: Insteon Serial PLM | AD2USB for Vista Alarm | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting Platform: HP h8-1360t, Windows Server 2012 R2, i7-3.4GHz, 16GB memory
I just wanted to make sure 100% since i"m trying to figure out why it is not working anymore. The file has been compressed with ext 7z. IT HS 3. The device in question is 0F.5A.65.
Thanks, very much appreciated. I'm successful in adding devices thru the plm but when I try to read the links via the plugin, it gives me that error. It looks like that it is stuck on link number 1 ", "The link table and device settings could not be retrieved for your device. "although the "Test Communications" is always successful 100%
Added more links, same issue. Attached is the log file zipped with ZIP extension. As a note, I'm able to control the responders (Insteon lights with the remote control) the only issue is adding it to HS or retrieving the links.
The max hops is set to 4, changing it, did not make a difference. Please do not worry, something to do with the device and since it is not a common, it is not worth spending more time on it. As always, thank you for all your help.
