Before I burden you with the details I want to make sure that this problem has not already been solved.
I have searched the forum everyway I can, but don't see a solution to my problem?
I have two Zee S2 controllers at two different locations.
Both are doing Z-Wave, Insteon using 2413U, and X-10 via Insteon plugin.
When I mark and delete an Insteon device in the Insteon device management screen - suddenly ALL Insteon devices are GONE from this table.
All the devices still show up on the HS device management page, and they all work.
Nothing will bring them back into view on this table.
When I tried to add an existing Insteon device it says "device already exists", which makes me think they are still there, just out of view?
When I add a NEW Insteon device, one the system has never seen, suddenly the entire Insteon Device Management table refills and all is well???
Until I try to delete an Insteon device, rinse and repeat...
This has repeated many times on both of the Zee S2 controllers I have.
My hope is that you have seen this issue and can direct me to the post I need and not consume a bunch of your time.
Thanks in advance for assistance...
