Long time user Mark, but now that I'm using HS4 I don't see how to add X-10 Devices?
HS-4 installing X-10 Devices
are you able create a generic device hs HS4 and assign it an x10 code?Mark
HS3 Pro 3.0.0.534
my plugin never supported 'creating' x10 devices because this was supported in HS3.HST has clearly removed the ability to assign an x10 code to a virtual device.
this is going to be a problem. I'm not planning on modifying my hs3 plugin to support anything that broke in HS4.
I will deal with this in my HS4 pluginMark
HS3 Pro 3.0.0.534
Originally posted by mnsandler View Postmy plugin never supported 'creating' x10 devices because this was supported in HS3.HST has clearly removed the ability to assign an x10 code to a virtual device.
Originally posted by Isk82 View Post
Your plugin absolutely did support creating X-10 devices simply by assigning a code, which has for some reason removed. I now have Insteon X-10 devices that I can't even tell what address they are, so I can't even copy a device and change the address. Ever since this X-10 plugin came about that feature is gone from your plugin. This doesn't happen by accident. The new X-10 plugin does not support a 2413U, and my Raspberry Pi doesn't have a serial interface. How am I supposed to use a CM11a serial interface with a Raspberry Pi? This absolutely should be part of your plugin (as it was, and working with the HS3 version) because Insteon switches also have X-10 addresses.
