Originally posted by mrceolla
View Post
"Hub stopped responding" after some inactive time it seems
This topic is closed.
very strange. everyone else that is using a hub with v3.0.7.36 is working fine. I made specific changes between 3.0.7.1 and .36 to fix some buffering issues.
the mystery sequence is 027F0206. let me know if you see this with 3.0.7.1. this sequence just doesn't mean anything to the hub; its very strange.
can you increase Max Hops if you experience issues in the near future.
Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postvery strange. everyone else that is using a hub with v3.0.7.36 is working fine. I made specific changes between 3.0.7.1 and .36 to fix some buffering issues.
As to max hops, now that I have a more stable system, I'll be putting in SwitchLincs all over the house. That mesh should improvet ransmissions I would think.Attached Files
Claude,
looks like these messages are received every 30 mins or so. check your events.
something on the network is generating these bogus message that the hub is ingesting and causing problems.
check for any device that is polled every 30 minutes.
Try pulling the air-gap on each switch, see if you can correlate the messages with some other events in your home/home automation.Mark
HS3 Pro 4.2.19.5
I checked all my events and none have a ~30 minute interval, actually none have any type of interval. I have old events that refer to non-existing devices, but the events page shows they have not been run for over a year and a half.
"Pulling air-gap on each switch" - I have only LampLincs so far that I have been reset multiple times; SwitchLincs are my next install once I feel comfortable with the stability of the system, but not yet part of the system..
"something on the network is generating these bogus message that the hub is ingesting and causing problems" - Agreed, but how do I nail this one ? I have detailed logging set and nothing pops up.
I know, this is not an obvious bug, but I still need to nail this one before installing Insteon further.
start unglugging non-insteon devices or turning off entire circuits to see if you can isolate the problem. the insteon/hs log can only tell you when the noise goes away; it can't tell you where its coming from.
add filterlincs to known devices that cause problems (computer, UPSs, TVs, wall adapters, etc)Mark
HS3 Pro 4.2.19.5
