Bad Link
    Bad Link
    Hi,
    I'm using the plugin in HS4. Today a light controlled by Insteon turned on and off with no physical intervention. I had a look in the HS log but there was nothing. I then decided to look in the plugin config to see if anything looked amiss.
    I came across this;
    As you can see it is suggesting there is a bad link to an unreferenced group.
    I don't have any groups;
    Any suggestions as to why it is showing a group I don't have and whether or not I should delete Link#2.
    Cheers
    no idea why it the switch would go on/off. check your events just in case.
    it could be a leftover link from the factory. you can look at the link data in the [device] section of the insteon.ini. Look at link #2 and see if you recognize an insteon id in bytes 3-5
    either way, you can delete the link
    Mark
    HS3 Pro 3.0.0.534
      Deleted - thank you.
