Device Links "Load Has Control" multiple instances good or bad?
    Mark,
    Rebuilding my house installing Insteon Switches I've noticed for all of my devices there is an inconsistent number of Links in the device Link Table. none of the devices I'm referring to are Linked or Sync'd to another device they each stand alone....
    Should I have multiple "Load Has Control" links on a switch? will it help the system to delete them?
Name:	Link Switch r1.jpg
    Devoir
    you can delete the extra dup links. you can delete all three and then reprogram the device for homeseer to make sure you get the correct link reprogrammed.
    Mark
    HS3 Pro 3.0.0.534
      mark,
      Many thanks for the confirmation and direction on this
      Devoir
        Glad to help. Good luck with the rest of the rollout.
        Mark
        HS3 Pro 3.0.0.534
