Beep Beep Insteon 2477S SwitchLinc On/Off Dual-Band Remote Control Switch
    Just install the 12th Insteon 2477S SwitchLinc On/Off Dual-Band Remote Control Switch.
    Every time you touch the switch to turn ON/Off it beeps or chirps ..... I can't figure out how to make is stop making a sound it's like it's the link mode or Tap Mode....
    I don't see any place in the manager to eliminate the chirp...........any thoughts on what I need to change to stop this sound ...
    Click image for larger version  Name:	Link Switch r4.jpg Views:	0 Size:	61.1 KB ID:	1446021
    Devoir
    Have you try a manual factory reset? You will need to reprogram the device afterwards.
    Mark
    HS3 Pro 3.0.0.534
      Mark
      Many thanks for the direction. I followed this Insteon video to factory reset the unit...... never knew about the "AIR GAP" technique to reset the unit.
      https://www.youtube.com/watch?v=V1aPQX8rjJ4
      reprogrammed the links and it works perfectly....
      Devoir
        Glad you got it working.
        can you post the devicetype= setting from the [device x] section in the insteon.ini
        i might be able to add the Beep setting to this device type
        Mark
        HS3 Pro 3.0.0.534
          Here is the switch.
          [Device 40]
          DatabaseDelta=1
          DeviceID=34.09.11
          DeviceLocation=Living Room
          DeviceName=Light Spot Fireplace
          DeviceType=022A
          EEValues=LEDBrightness=31,OpFlags1=100
          FailedInteractions=19
          FirmwareVer=43
          HopData=137,126,6,5
          LastContact=1/3/2021 4:55:02 PM
          Link 1=AA 00 33 E2 9D 00 FE 00 1
          Link 2=E2 01 33 E2 9D 00 00 01 2
          Link 3=A2 FE 33 E2 9D FF 1F 01 3
          LinksDownloaded=1
          NumLinks=3
          PollingInterval=0
          Protocol=3
          RecentDatabaseDelta=1
          SyncLinkedDevices=0
          TotalInteractions=98
          Thanks for the assistance...
