Newbie post: unable to initialize interface
    Hi, new user, new RPi4 HS4 build. Just installed the Insteon plugin today, having trouble getting the Smarthome PowerLinc Dual Band 2413U PLC to work (just arrived from Smarthome today). It's plugged into the same powerstrip as the Raspberry Pi ps, the PLC light comes on. Here is the error log below. The USB cable is new and plugged into the RPi.
    Thanks for the help.
    Insteon Plug-in Error Log Generated 1/9/2021 3:35:21 PM
    -----------*Error Message*----------------
    Error: Forced error / log generation -- 1/9/2021 3:35:21 PM
    --------*Initialization Log*--------------
    1/9/2021 3:31:43 PM - Host System: 10.0.0.174 (HS4PiV3) 4.1.10.0
    1/9/2021 3:31:43 PM - Plugin HSPI_Insteon.exe version: 3.0.7.1
    1/9/2021 3:31:43 PM - Insteon Support library (Insteon.dll) version: 1.0.7.1
    1/9/2021 3:31:43 PM - RegisterCallback Completed
    1/9/2021 3:31:43 PM - Enter InitIO
    1/9/2021 3:31:43 PM - Enter InitPlugin
    1/9/2021 3:31:43 PM - Global initialization of plug-in required, starting up.
    1/9/2021 3:31:43 PM - Initializing Insteon hardware interface...
    1/9/2021 3:31:43 PM - In ProcessRawReceiveThread
    1/9/2021 3:31:43 PM - Initializing Interface...
    1/9/2021 3:31:43 PM - In PLMBuffer_ProcessBufferThread
    1/9/2021 3:31:43 PM - Insteon hardware interface initialization failed.
    1/9/2021 3:31:43 PM - Exit InitIO
    -----------*Pre-Error Log*----------------
    1/9/2021 3:31:43 PM - Please visit the plugin configuration page, and enter a valid port, then restart HS.
    --------*End Pre-Error Log*--------------
    --------*Start /usr/local/HomeSeer/Config/Insteon.ini*--------------
    [Config]
    DetailedLog=1
    DisablePolling=0
    DoCleanups=1
    InterfacePort=53.C2.D7
    MaxHops=2
    NumRetries=5
    SortDeviceLinks=0
    UseLocation2=0
    WaitTimeout=3
    X10Enabled=0
    --------*End /usr/local/HomeSeer/Config/Insteon.ini*--------------
    Welcome.
    you need to enter the Linux port not the Insteon id
    hover over the blue ? Next to see the available ports on your system.
    Mark
    HS3 Pro 3.0.0.534
      Thanks Mark, /dev/ttyUSB0 did the trick. Looking forward to moving my ISY994 programs to HomeSeer.
        Glad you got it working. Enjoy!
        Mark
        HS3 Pro 3.0.0.534
