Adding Devices... am I missing something?
    Greetings Mark.
    I am in the process of upgrading my old H2Pro system to H4Pro. I am a fan of your Inteon plugin so purchased and installed the HS3 plugin. However, I am at a loss trying to figure out how to add devices.
    Ken
    Welcome.
    Everything regarding the plugin can be access via the Insteon Configuration pages which should be accessible from the the HS4/Plugins page
    then goto the Manage Device page. From there there is a "Add a New Insteon Device" button towards the button
    Mark
    HS3 Pro 3.0.0.534
      When I follow your instructions I get the following screen.
        Can i see the hs startup log? i dont think the plugin is finding your interface on com10
        Mark
        HS3 Pro 3.0.0.534
          2/7/2021 11:02:42 AM HomeSeer~!~Database~!~Opening (Mode=Read Only) up HomeSeer LOG database C:\Program Files (x86)\HomeSeer HS4\Logs\HomeSeerLog.hsd
          2/7/2021 11:02:42 AM HomeSeer~!~Startup~!~Loading Settings
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Settings Loaded.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~*************************************** *****************************************
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~ HomeSeer version 4.1.11.0 Edition: HS4 Pro Starting Now
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Creating Class Objects...
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~COM port classes started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Application interface class started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Web server class started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~E-Mail SEND class started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~E-Mail RECEIVE class started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Plug-In Interface class started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Local voice recognition class started.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Loading configuration file ...
          2/7/2021 11:02:43 AM HomeSeer~!~Info~!~Loaded 79 Devices.
          2/7/2021 11:02:43 AM HomeSeer~!~Info~!~Loaded 9 Events.
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~HomeSeer version is: 4.1.11.0
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Creating Speaker Client Interface Object...
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~This version of HomeSeer is registered as a HS4PRO version.
          2/7/2021 11:02:43 AM HomeSeer~!~Web Server~!~Local IP address (subnet) is: 192.168.1.17 (255.255.255.0)
          2/7/2021 11:02:43 AM HomeSeer~!~Web Server~!~Web Server started on port 80
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Start automation engine...
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Initializing Speaker Client Interface
          2/7/2021 11:02:43 AM HomeSeer~!~Speech~!~Listening for remote speaker connections on port 10401
          2/7/2021 11:02:43 AM HomeSeer~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS4\Data\Energy\Energy.hsd
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Updater services starting...
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Starting Find service...
          2/7/2021 11:02:43 AM HomeSeer~!~Info~!~Remote plug-in API interface started on port 10400
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Checking for available plug-ins
          2/7/2021 11:02:43 AM HomeSeer~!~Plug-In~!~Found plug-in: BLDSC, version: 2.0.66.0
          2/7/2021 11:02:43 AM HomeSeer~!~Plug-In~!~Found plug-in: HSInsteon, version: 1.0.0.9
          2/7/2021 11:02:43 AM HomeSeer~!~Plug-In~!~Found plug-in: Insteon, version: 3.0.7.36
          2/7/2021 11:02:43 AM HomeSeer~!~Plug-In~!~Found plug-in: RCSStat, version: 3.0.0.14
          2/7/2021 11:02:43 AM HomeSeer~!~Plug-In~!~Found plug-in: UltraGCIR3, version: 3.0.6551.16959
          2/7/2021 11:02:43 AM HomeSeer~!~Startup~!~Initializing Plug-Ins
          2/7/2021 11:02:44 AM HomeSeer~!~Info~!~Plugin BLDSC has connected. IP:127.0.0.1:51739
          2/7/2021 11:02:44 AM HomeSeer~!~Starting Plug-In~!~Initializing plugin BLDSC ...
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~Initializing BLDSC...
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~BLDSC version is: 2.0.66.0
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~Loaded configuration successfully
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~Partitions have been loaded
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~Zones have been loaded
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~Users have been loaded
          2/7/2021 11:02:44 AM Legacy-Plugin~!~BLDSC start~!~BLDSC plugin has been initialized
          2/7/2021 11:02:44 AM HomeSeer~!~Starting Plug-In~!~Plugin BLDSC started successfully in 245 milliseconds
          2/7/2021 11:02:44 AM HomeSeer~!~Starting Plug-In~!~BLDSC loaded in 499 milliseconds
          2/7/2021 11:02:44 AM HomeSeer~!~Plug-In~!~Finished initializing plug-in BLDSC
          2/7/2021 11:02:44 AM HomeSeer~!~Info~!~Plugin UltraGCIR3 has connected. IP:127.0.0.1:51741
          2/7/2021 11:02:44 AM HomeSeer~!~Starting Plug-In~!~Initializing plugin UltraGCIR3 ...
          2/7/2021 11:02:44 AM HomeSeer~!~Starting Plug-In~!~Plugin UltraGCIR3 started successfully in 320 milliseconds
          2/7/2021 11:02:44 AM HomeSeer~!~Starting Plug-In~!~UltraGCIR3 loaded in 499 milliseconds
          2/7/2021 11:02:44 AM HomeSeer~!~Plug-In~!~Finished initializing plug-in UltraGCIR3
          2/7/2021 11:02:45 AM HomeSeer~!~Info~!~Plugin RCSStat has connected. IP:127.0.0.1:51743
          2/7/2021 11:02:45 AM HomeSeer~!~Starting Plug-In~!~Initializing plugin RCSStat ...
          2/7/2021 11:02:45 AM HomeSeer~!~Starting Plug-In~!~Plugin RCSStat started successfully in 78 milliseconds
          2/7/2021 11:02:45 AM HomeSeer~!~Starting Plug-In~!~RCSStat loaded in 299 milliseconds
          2/7/2021 11:02:45 AM HomeSeer~!~Plug-In~!~Finished initializing plug-in RCSStat
          2/7/2021 11:02:45 AM HomeSeer~!~Info~!~Plugin Insteon has connected. IP:127.0.0.1:51745
          2/7/2021 11:02:45 AM HomeSeer~!~Starting Plug-In~!~Initializing plugin Insteon ...
          2/7/2021 11:02:45 AM Legacy-Plugin~!~Insteon~!~Insteon Support library (Insteon.dll) version: 1.1.7.36
          2/7/2021 11:02:45 AM Legacy-Plugin~!~Insteon~!~Please visit the plugin configuration page, and enter a valid port, then restart HS.
          2/7/2021 11:02:45 AM HomeSeer~!~Starting Plug-In~!~Plugin Insteon started successfully in 39 milliseconds
          2/7/2021 11:02:45 AM HomeSeer~!~Starting Plug-In~!~Insteon loaded in 199 milliseconds
          2/7/2021 11:02:45 AM HomeSeer~!~Plug-In~!~Finished initializing plug-in Insteon
          2/7/2021 11:02:45 AM HomeSeer~!~HSTouch Server~!~Server started on port 10200
          2/7/2021 11:02:45 AM HomeSeer~!~Startup~!~HStouch server started, waiting for clients to connect.
            I just went in and turned the plugin off and back on. It is working now.
            Thank you, Mark.
            Ken
              Glad you got it working.
              Mark
              HS3 Pro 3.0.0.534
