Hey everyone,
I have a small Insteon installation with about 25 light switches that I have been using for the past 9 years.
I originally had bigger plans with an ISY994 and various PLM options, but ran into a problem with Insteon PLMs not being compatible with the local 50Hz electricty supply and had to return most of my kit and fall back to use a simple Insteon Hub, which has worked reasonably well.
I'd now like to expand my setup with HomeSeer for better logic, and to add a bunch of Insteon motion and door sensors.
I am currently running a trial of HomeSeer and the Mark's Insteon plugin on a Raspberry Pi and have just started to fiddle with things.
I am not sure if the best practice would be to add the motion and door sensors to the Insteon Hub and then manage them via the Insteon plugin connection to the hub, or if I should start fresh and use a 2448A7 USB adapter installed in the Pi. Seems like less work to work through the Insteon Hub as my existing installation is already up and running, the downside is sometimes these hubs fail.
The USB adapter would mean I'd have to start over, but might not be a bad idea considering how old my installation is, and perhaps performs better than going through the hub?
Any recommendations or thoughts on this?
Kim
Kim
