Insteon Max Device Count vs System Response time
    #31
    Originally posted by JimSpy View Post
    A group Off cmd is always going to turn every participant Off.
    Now, here's something I did not know and always wondered. Does this apply to turning off a SCENE in HomeSeer?
    does homeseer have a SCENE construct?
    within the insteon plugin a scene = a group
    Mark
    HS3 Pro 3.0.0.534
      #32
      I think z-wave uses the scene term for groupings
      HomeSeer 3, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Smart Speakers, Foscam cameras, Amcrest camera, RCA HSDB2a doorbell
        #33
        Well, yes, Homeseer calls them SCENES, Insteon calls them GROUPS. So you're saying that turning a GROUP off turns all members off, regardless of how they behave with a GROUP ON command.
        With the Insteon PI, creating a GROUP in Insteon automaticallly creates a corresponding SCENE in HomeSeer. (I don't know what happens with other hardware platforms). The HS SCENE can then be toggled on or off, or you can just select the <BLANK>, which, I have no clue what that does. But I always wondered what turning off a SCENE meant, and now I know.
        Jim Speiser
        Still don't know squat
          #34
          ‚Äč‚Äč
          groups can adjust every light to different levels and different ramp rates. A group On command can even turn some lights On and others Off. A group Off cmd is always going to turn every participant Off.
          Sorry to hijack the post.
          When I set the group to 'Off' in an event, the log shows that devices in that group are turned 'On'.
Name:	210427 Event.png
Name:	210427 Group definition.png
            #35
            Originally posted by claude View Post
            ‚Äč‚Äč
            how do the actual devices respond? do they turn on or off?
            Mark
            HS3 Pro 3.0.0.534
              #36
              I do it a little differently. I have separate groups for "off" events. I needed to do this since in a lot of cases I have the lights slowly dim down using the ramp rate settings. I found that it works best if instead of turning the "off" group on, I turn the "off" group off. This was the only way to get any keypadlinc buttons in the group to turn off.
                #37
                Originally posted by joegr View Post
                I do it a little differently. I have separate groups for "off" events. ... I found that it works best if instead of turning the "off" group on, I turn the "off" group off. This was the only way to get any keypadlinc buttons in the group to turn off.
                Same here, for the same reason. I definitely ran into that with my old keypadlincs. I don't think I had a need for that particular situation with any of my newer ones.
