I replaced a failed 8-button keypad with a new device that came as a 6-button. I used the Replace Device function. That worked, but the new device had zero links. I did the Program Device for HomeSeer - that worked. I changed the #buttons to 6 and then back to 8 - that worked. I then did Edit Links to program links from the buttons to devices. The 1st one worked. When I attempted the 2nd one, as soon as I selected the controlled device, the page went back to the main configuration page. i tried this a few times. I looked in the Insteon Error Repot log and found error message: "Error: Error in PagePut: Index was outside the bounds of the array. -- Details System.IndexOutOfRangeException: Index was outside the bounds of the array.at Insteon.Support.WebInterface.PagePut(String& data)"
I shut down and restarted HS. Now, on startup I get an error and fins the same message in the log, and, the Keypad device no longer appears in the HS devices nor in the Insteon configuration. Attached are the insteon.ini, startup.ini, HomeSeerData, and Insteon Error Report.log files. Please advise.
