Reading through some of the contracts it was mentioned that all is required is to make sure the access point is on the correct phase and to "reset communications". What is meant by "reset communications"? I don't see an option for that in the plugin.
Access Point 2443 - Reset Communications
there really is no management for the access points. here is a link to the manual http://cache.insteon.com/documentation/2443-en.pdf
as far as 'reset comms' that is a plugin function for an individual device registered within the plugin. its called "reset comm data" in hs3; "reset stats" in hs4
see the plugin Devices page
Mark
HS3 Pro 4.2.19.5
