Hi,
I'm replacing a very old 2486D KeypadLinc with a 2334-232 KPL Revision 8.2 3922 which just arrived today from the new Insteon store.
The new KPL beeps in the beginning, but the routine fails on step one with:
Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
HS Log shows
Legacy-Plugin
Insteon
Your system could not be reprogrammed.Program And Replace Device - The destination device could not be programmed, function aborted before system/device changes were made.
Legacy-Plugin
Insteon
Did not receive a response from (70.0F.18). Try #5 failed.
Legacy-Plugin
Insteon
Received Upper Kitchen Insteon Motion Sensor II Occupancy Sensor: (4D.C8.B8) Go OFF
Legacy-Plugin
Insteon
Received Upper Kitchen Insteon Motion Sensor II Occupancy Sensor: (4D.C8.B8) Go ON
Legacy-Plugin
Insteon
Step 1 of 5: Programming new device with links...
Legacy-Plugin
Insteon
Program And Replace Device - Process starting... (04.F8.E3->70.0F.18)...
Legacy-Plugin
Insteon
Pass 2, Now attempting to reprogram your system for the replacement device...
Legacy-Plugin
Insteon
Pass 1, updating devices that appear to have stale link tables...RF devices are ignored...
I did perform a factory reset on the new device to see if that fixed the problem, but it did not. Any other ideas?
Mike
HS Log shows
10/14/2022 6:07:13 PM
Legacy-Plugin
Insteon
Legacy-Plugin
Insteon
10/14/2022 6:07:08 PM
Legacy-Plugin
Insteon
10/14/2022 6:06:54 PM
Legacy-Plugin
Insteon
10/14/2022 6:06:53 PM
Legacy-Plugin
Insteon
Legacy-Plugin
Insteon
10/14/2022 6:06:51 PM
Legacy-Plugin
Insteon
Legacy-Plugin
Insteon
Mike
