My PLv2 with updated firmware will not be here until the 4th, but while I was planning my system tonight I ran into a scenario that I could not readily find the answer to.
Normally if you wanted to create an event in HS with X10, you could simple set your palmpad or other controller to a specific letter (D for example) and when D-5 was received, you could perform an action or actions based on receiving that code.
How does this work with an Insteon ControlLinc? Do you leave the button unlinked and if so, how to you handle the buttons reception within HS? Is it as simple as XX.XX.XX.1 or something to that effect for button 1 or is it more complicated?
Any insight is appreciated.
Jim
Jim
