1/26 11:00am - Rick said that he has now posted it to the updater.
I was hoping to give builds a few days here before they got to the updater, but changes have been coming fast enough that I'll have to try something different. This time it took a while to get the build into the updater.
Jon
Beta .6 has been posted to the updater. There are no updates to the SDM so any SDM issues will still be there.
There are quite a few changes internally, here are the highlights:
1) When adding a new device the plug-in will check to make sure it can be communicated with, and will get the device type and firmware version for use later.
2) Full error report generation has been added. This log will be complete no matter what logging level is set in the plug-in. The plug-in will generate a log on any exception, and can be generated from within the plug-in config so that problems can be diagnosed more easily.
3) The problem where HomeSeer would update the 'On" time whenever the device was polled is fixed.
Jon
Jon
Jon
