Does anyone know what this means in the log. After boot, none of my x10 devices are working. The Insteons are working great.
The clue I have is that my PowerLinc USB 2414U is on the USB port, not the COM port.
1/26/2006 7:13:45 AM - Info - Initializing X10 Plug-in: INSTEONBASIC On COM Port 1
1/26/2006 7:13:45 AM - Info - Initializing Plug-in: INSTEONBASIC
1/26/2006 7:13:45 AM - INSTEONBASIC - RegisterCallback Completed
1/26/2006 7:13:46 AM - INSTEONBASIC - Error in InitPlugin: System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure at SDM3Server.ISDM3.set_blocking(Boolean Value) at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/26/2006 7:13:46 AM - Error - Initializing X10 interface INSTEONBASIC: System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure at SDM3Server.ISDM3.set_blocking(Boolean Value) at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/26/2006 7:13:46 AM - Info - Done initializing X10 interface INSTEONBASIC
1/26/2006 7:13:46 AM - Startup - IR Label file (config\irlbl.cfg) missing or corrupt, creating new file
1/26/2006 7:13:46 AM - Info - Done initializing infrared interface
1/26/2006 7:13:46 AM - Info - Initializing Plug-in: INSTEONBASIC
1/26/2006 7:13:47 AM - INSTEONBASIC - Error in InitPlugin: System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure at SDM3Server.ISDM3.set_blocking(Boolean Value) at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/26/2006 7:13:47 AM - Error - Initializing interface: INSTEONBASIC->System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure at SDM3Server.ISDM3.set_blocking(Boolean Value) at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/26/2006 7:13:47 AM - Info - Done initializing plug-in INSTEONBASIC
