I just received my 2414S (SERIAL version) PLC, and have been trying to get it set up to control my first few Insteon switches with the plugin.
The plugin and SDM are loaded and I can get the SDM "setup" to come up in the tray area, but when I try to set the COM port the only choice I am given is USB. That's a bit less than helpful when all you have is a serial device.
Can someone guide me on this? The setup instructions that come with the 2414S consists of only a Quick Start Guide, which is basically worthless. I did update the com port on the setup / interfaces page, but that (curiously) only comes up when I enable X10. And the SDM seems to ignore it, anyway.
The plugin does not see the PLC, so I'm getting nowhere fast.
Joe
Joe
