I have been participating with Smarthome's beta of the IRLinc B2411R. This I assume is much like a RemoteLinc, but I am not sure as I do not own one.
I was successfully able to register the IRLinc with HS2, and HS2 successfully tracks the on/off states of anything the IRLinc controls. After explicitly reading the new link tables in all of the devices controlled by the IRLinc, HS2 tracks everything pretty well (I have not tested %on/off yet).
However, what I want to do is trigger and event in HS2 when a specific button is pushed on the IRLinc Remote. I was told by Smarthome that the IRLinc broadcasts the on/off command to a linked device with the group/button.
I need to do 2 things, get a link in the IRLinc that is HS2's address (usually done when the IRLinc is listening and I hit the set button the side of the controlled device, but I do not know how to hit the set button on the side of HS2? The other is I need to get HS2 to respond to a specific Group/Button command (other than #255 or what ever that is that HS2 always sets up).
I suppose if I had a way to create links (create all attributes of links), I could make the links and then download them into the IRLinc and also HS2. Or am I just missing the obvious?
