Feature Requests for the Mark Sandler Insteon PLM Plug-In
This is a sticky topic.
    Alternate Interfaces
    Hi Mark
    I use an insteon hub as a backup interface to my primary interface serial PLM. I use it to as a backdoor way to control some mission critical devices. Since the hub is not recognized by the Insteon Plug in, it shows up as an unregistered device address.
    As a feature request, could we have an area on the set up pages where we enter the addresses of alternative interfaces and it lists the devices that those interfaces control? That would help remove the unregistered address alerts for devices where I do want to have the unregistered address.
    Thanks for considering
    Jono
      Originally posted by randy_h View Post
      On the Insteon Plugin, Edit Insteon Device page for Motion Sensors, I would like to see a "Settings last read timestamp" and maybe even a count of On cmds that have occurred since last read.
      This would be useful for me when troubleshooting and setting up Motion Sensors. Something similar to mock up pasted below:
      Thank you for your consideration.
      look for this in the next beta release 3.0.6.14 or later
      Mark
      HS3 Pro 3.0.0.534
        Originally posted by jono View Post
        Hi Mark
        Jono
        Jono,
        No problem. I already do this for secondary PLMs. you will just register the Hub like a regular device. As long as you have the other devices registered in the plm that are also registered with the hub, the unregistered issue should go away.
        Look for this in the next beta 3.0.6.14
        Mark
        HS3 Pro 3.0.0.534
          Hidden Door Sensor LED ON/OFF
          Hi Mark,
          Thanks for all the time and energy you have put in to create such a great plugin.
          Quick question (or request I suppose). Is it possible to turn the LED on and off on the hidden door sensor?
            Originally posted by cloomis View Post
            Hi Mark,
            Yes its possible. Look for this feature in the next beta
            Mark
            HS3 Pro 3.0.0.534
              Hi Mark,
              Quick question in regards to a new 8 button keypad I recently installed. The option for "Non-Toggle Off" is no longer a choice for "Button Mode". Is this a limitation of the new keypads?
                Yes. SH removed that feature. Use non toggle on and set the levels to 0 or off for responder devices.
                Mark
                HS3 Pro 3.0.0.534
                  Thank you for the quick response!
                    Insteon Virtual links
                    Hi Mark,
                    I read in an old message post about you adding virtual Insteon links to the plugin. What is the status of that?
                    Thanks very much,
                    Patrick
                      Originally posted by pmendiuk View Post
                      Hi Mark,
                      Thanks very much,
                      Patrick
                      Patrick,
                      not sure what you are referring to. can you point me to the thread or post
                      Or what functionality are you looking for?
                      Mark
                      HS3 Pro 3.0.0.534
                        Utility to facilitate setup of N-way switching
                        Hi Mark,
                        I'm a recent convert to Insteon from the Z-wave world, and I have to say that your plugin is, in part, to blame. The visibility and control that your plugin provides into the connectivity between my Insteon devices was instrumental in my decision to switch nearly all of my smart home devices from Z-Wave to Insteon.
                        All of that said, I do have a feature request that, I believe, would make the management of links easier.
                        Imagine that I have two dimmer modules and three keypads. Say I want to each keypad to have a button that controls the pair of dimmers as well as keeping all of dimmers and the buttons in sync, it can be a bit tedious to get things set up:
                        • Keypad1 Button 1 cross-link Dimmer1
                        • Keypad2 Button 1 cross-link Dimmer1
                        • Keypad3 Button 1 cross-link Dimmer1
                        • Keypad1 Button 1 cross-link Dimmer2
                        • Keypad2 Button 1 cross-link Dimmer2
                        • Keypad3 Button 1 cross-link Dimmer2
                        • Keypad1 Button 1 cross-link Keypad2 Button 1
                        • Keypad1 Button 1 cross-link Keypad3 Button 1
                        • Keypad2 Button 1 cross-link Keypad3 Button 1
                        • Dimmer1 cross-link Dimmer2
                        Additional challenges occur when it comes to revising this set up:
                        • Say I want to remove Keypad2 Button1? I have to go through and delete 8 links manually.
                        • Adding a new dimmer or maybe just control via another button requires bouncing setting up several new links.
                        I always miss a step, and my wife is the first to notice.
                        Here's my request: It'd be very handy if I could take a group of devices and check box for "keep all of these in sync", and the Insteon plugin would take care of generating all of the appropriate links. If I add or remove devices from said group, the appropriate links would be added or removed. It'd make my life easier, so I'm sure it'd help others, as well.
                        I'd love to hear your thoughts!
                          Originally posted by whippersnapper View Post
                          Hi Mark,
                          Have you tried using the Groups feature in the plugin to do this? each group could have a controller which would be a kpl Btn. you would need three different groups to setup the scenario you outlined
                          I don't understand why you would have 3 different kpl btns controlling the same two dimmers unless you had different on-levels and ramp-rates set for each button.
                          Mark
                          HS3 Pro 3.0.0.534
                            This is for my bedroom -- I have a keypad at the door, a keypad on my nightstand, and a keypad on my wife's nightstand. There are common sets of lights that I'd like to be able to control from each keypad, as well as keep the buttons all in sync.
                            I'm aware of the groups functionality, but having to set up multiple groups for the same function is still a bit tedious. What I'm suggesting is the addition of a layer of abstraction, allowing me to define a set of controllers as well as a lighting scene, and have all of the links maintained beneath the hood.
                              I haven't read through this whole thread, so not sure if this was requested or not, but..
                              Can you make it an option to use Location 1 instead of Location 2?
                              I use Location 1 for Room and Location 2 for Device classification as I only have a 1 story house. Right now it puts the Room name in my Device Classification field.
                              MeiAutomtion Home
                                when does the following occur? when you add a device, or when?
                                can you post a screen shot of the issue
                                Mark
                                HS3 Pro 3.0.0.534
