Originally posted by Jon
View Post
Feature Requests for the Mark Sandler Insteon PLM Plug-In
This is a sticky topic.
Mark
HS3 Pro 4.2.19.5
Originally posted by joegr View PostWould it be reasonably possible to have two different response timeout settings? The idea would be to have one for simple responses to on/off/dim/... commands, and another one for link programming and other more complicated tasks.Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Post
that's an interesting idea. what are your thoughts on the range of values for each timeout setting?
I would consider reading values from battery devices (settings, battery level, changing settings after x triggers, ...) as the complicated timeout.
I would like to get the simple timeout down to one second, or at least down to two. I would set the complicated one to five seconds, I think. Right now I have the single timeout set to a compromise of three seconds.
I would consider reading values from battery devices (settings, battery level, changing settings after x triggers, ...) as the complicated timeout.Mark
HS3 Pro 4.2.19.5
Originally posted by smithdavee View PostIs it possible to cancel a job that the plugin is running. Such as a device that does not respond. It would be nice to cancel it.Mark
HS3 Pro 4.2.19.5
Originally posted by smithdavee View PostA reprogram a device that is failing, or even just reading a device. Also the comms test.Mark
HS3 Pro 4.2.19.5
Originally posted by Simplex Technology View PostAny chance of getting a "Remove all existing links" option for adding devices?
the cleanest and fastest thing is to factory reset the device before adding. This makes the add process much faster and more reliable. Unfortunately there is no 'reset' command i can send (its not part of the protocol).
I can't say yes or no at this point. I'll have to review the add process code.
Mark
HS3 Pro 4.2.19.5
so the irony is the plugin must create a link to the device before it can read and delete from the link database. so the plugin would have to create the first time link, read all the links, find this new one (because the plugin doesn't know where in the database it was written), and then delete all the others. And then possibly move the initial link to the beginning of the link database to keep the database link table clean. And then write the device specific links.
Excellent plugin BTW I bought yesterday and moved 46 devices over for testing from the ISY
