Attached is a beta of the next version of the PLM plugin. Below lists the New Features and Fixes.
I don't have a copy of the SDM which is required to build a version for the PLC. If someone can post a copy of the SDM3Server.dll file, i think that is all i need.
NOTE: Please backup your HS environment before installing and running this version. Specifically the config\insteon.ini file, hspi_insteon.dll, and your homeseer mdb file.
Installation: shutdown HS, backup the your installation, extract the hspi_insteon.dll to your homeseer directory, restart HS.
Please post issues and bugs as replies to this thread.
Version 1.2.0.0 beta
New Features
-Support for SwitchLinc Relay with Sensing (2476S2 -15 Amps, Rev 5.0+) [Untested]
-Sets default on-level and ramp rates for i1 Switchlinc Dimmers (requires power cycling the switches)
-Preserves the Comm Reliability stats from session to session. They are saved at shutdown and reloaded at startup.
-Resets Comm Reliability stats using the new button on the "Edit Insteon Device" page
-Provides an enhanced user interface for registered devices and groups
-Allows the Global insteon All Devices group to be permanently renamed using the standard Hs device property page.
Fixes
-Revised Polling Timer so polling would restart if plugin is restarted while HS running.
-Fixed a problem with i2 KeypadLinc Relay device settings for 6 vs 8 btn setup.
-Modified startup routine so Groups are only changed and saved if necessary. Minimizes startup log entries.
-Revised routine that checks and reports Database Link changes. Should reduce false Warnings.
New Features
Fixes
