About 2 weeks ago I grabbed 2 keypadlincs (an 8 & 6 button), 4 insteon dimmer switches, 2 access points, and a PLC.
The switches seem to work fine, and I was able to control the dimmers w/ the Keypads (though I have a problem with that too).
My main issue though is that I haven't been able to successfully connect the PLC to the devices. I've tried a ton of different software, and the most I've been able to do is get the HS plugin to connect to 2 of the switches. The others are all right next to each other, but can't seem to connect to the PLC. Also the PLC never seems to get any messages from the switches. With other software I've been able to connect to 0 of the devices.
Anyone have any suggestions on what the problem may be? I've been messing with it for 2 weeks and am getting really frustrated.
Also my other issue was that while I can control the dimmer switches with the keypads, if I turn the dimmers off, the keypads don't seem to update. I was under the impression that they would update the status of the dimmer, was I wrong about this?
