Hi all - I wanted to control the lighting in our out buildings. After talking to Smarthome, I was convinced that using multilple keypadlinc 6s would do the trick. And it did. I can check any one of three switches and tell if any of the outside lights are on and turn them on or off. Basically all three keypadlincs are multi-linked to each other.
I have been using Homeseer for a long time with X10. I now want to control the Insteon lighting with Homeseer and purchased a 2413U PLM. I have it working with 2.4.0.11 and one Keypadlinc. I had (nievely) thought that identifying a Keypadlinc device would only allow control of that device's address. It looks like I can control all three devices from one identified Keypadlinc.
My question is (drumroll): Since all three devices are multilinked at the switch and apparently addressable from Homeseer as main, A, and D, does it make sense to add the other device (keypadlinc) addresses to Homeseer? Being a newbie to Insteon, it seems that doing so might be confusing.
