Keypadlincs & Conditional Triggers
    If anyone can help I'd appreciate it...
    http://forums.homeseer.com/newthread...stthread&f=637
    the link you posted doesn't work. can you restate the issue here
    Mark
    HS3 Pro 4.2.19.5
      I'm trying to trigger scenes 2 ways...
      1) Keypadlinc button
      2) Setting a Device - using on/off status (web interface ,etc)
      So when the Device is set, I want it to trigger the Event AND turn the Keypadlinc button on.
      I thought I would set a Condition (using #1 & 2 above) and then within the Actions also set the device status and keypadlinc button. I fear this is creating a loop situation.
      Anyway to trigger the device & set the proper keypadlinc light - prefer all in one Event but I'll take it anyway I can
      thank you!
        thank you!
        you may just need an additional condition on the trigger to make sure the kpl light is off before triggering. this should prevent the event from running a second time
        Mark
        HS3 Pro 4.2.19.5
