I have an event on a switch with an Insteon special trigger of: transmits an On command.
Separately, I have an HS action that dims that same switch after an interval.
It appears that the HS action triggers the first event. I was expecting that only an action from the light would trigger the event.
Questions:
1- What is the expected behavior in the above scenario?
2- what constitutes 'transmits an On command' ? What if the light was at 100%, then sent a dim to 50% ? Is there any documentation on the specifics of the special triggers?
Questions:
