RemoteLink to trigger Event
This topic is closed.
    I had some events that were triggered by a specific button on my RemoteLink devices. They worked a few versions back but now do not fire off.
    HomeSeer is seeing the command How ever it does not do anything with it.
    1/18/2013 6:14:46 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 3A 4C 13 1F DA 41 11 06
    Here is what the event looks like.... pretty simple.
    Movie Time On Insteon device 'Living Room Remote Button 6: ' Transmits an On Command
    WHEN
    Everyday
    Device Command: Living Room Back Fan Light On
    Device Command: Living Room Fire Place Pots On Delay: 00:00:02
    Device Command: Living Room Front Fan Light On Delay: 00:00:04
    Device Command: Living Room Front Pot Lights On Delay: 00:00:06
    Device Command: Living Room Lamp On Delay: 00:00:08
    Device Command: Kitchen Island Light Dim to 100% Delay: 00:00:10
    Device Command: Kitchen Over Cabinet Lights On Delay: 00:00:12
    Device Command: Kitchen Pot Lights Dim to 100% Delay: 00:00:14
    Device Command: Kitchen Under Cabinet Lights Dim to 100% Delay: 00:00:16
    Movie Time Off Insteon device 'Living Room Remote Button 6: ' Transmits an Off Command
    WHEN
    Everyday
    Device Command: Living Room Back Fan Light Dim to 0%
    Device Command: Living Room Fire Place Pots Dim to 0% Delay: 00:00:02
    Device Command: Living Room Front Fan Light Dim to 0% Delay: 00:00:04
    Device Command: Living Room Front Pot Lights Dim to 0% Delay: 00:00:06
    Device Command: Living Room Lamp Off Delay: 00:00:08
    Device Command: Kitchen Island Light Dim to 0% Delay: 00:00:10
    Device Command: Kitchen Over Cabinet Lights Off Delay: 00:00:12
    Device Command: Kitchen Pot Lights Dim to 0% Delay: 00:00:14
    Device Command: Kitchen Under Cabinet Lights Dim to 50% Delay: 00:00:16
    Any Ideas?
    Dave
    WHEN
    Everyday
    WHEN
    Everyday
    Any Ideas?
    Dave
    Dave,
    the following msg is not the triggering msg:
    i would expect something like the following:
    1/18/2013 6:14:46 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 3A 4C 00 00 01 C7 11 06
    can you post more of the detailed log
    Mark
    HS3 Pro 4.2.19.5
      Originally posted by mnsandler View Post
      Dave,
      That is all there is Mark,
      The first line is Button 6 on and the second line is button 6 off
      1/18/2013 11:01:38 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 3A 4C 13 1F DA 41 11 06
      1/18/2013 11:01:49 PM Insteon Received STX 0x50 (Raw Insteon Rec):14 3A 4C 13 1F DA 41 13 06
      There is only one other error that I get when the Plug-in is started, and it is as follows. This is my Thermostat.
      1/18/2013 11:51:24 PM Insteon An Insteon device of type 050E was configured using the settings from the insteon.ini.
      1/18/2013 11:51:24 PM Insteon Please post this new device type in the forum so it can be permanently added to the plugin.
      1/18/2013 11:51:24 PM Insteon Note: This message will be eliminated once the device type is added to the plugin.
        Dave,
        My guess is there is a rf comm issue where you are using the remotelinc. Either something is interfering or there isn't another rf device close enough to repeat the msgs back to the plm
        please turn on detailed logging while you try the remotelinc next to the plm an see if you get additional msgs. if that works, then start moving away from the plm as you press the btns and see if you still get additional msgs. this will help you determine where you having rf issues.
        I once had a dual-band switchlinc stuck in transmit mode and it blocked out all other rf signals withing 25'. It wasn't easy to find. but one i reset the offending switch everything was fine.
        Mark
        HS3 Pro 4.2.19.5
          Dave,
          Mark,
          Detail logging is on and that is all I get from the logs.
          I do not have any dual band switches, just the PLM as well as 2 other RF receivers. I have tried putting the remote right next to the PLM as well as the receievers and get the same result. Same thing happens with my other remote link. These control individual devices just fine, it is just when I am trying to trigger something in Homeseer that they do not work.
          Here is the log when button one and two are pressed. These control individual switches and work fine.
          1/19/2013 11:25:14 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 3A 4C 13 1F DA 41 11 01
          1/19/2013 11:25:18 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 3A 4C 13 1F DA 41 11 02
          Dave
            Dave i would suggest relinking the remotelinc to the plm.
            if that doesn't fix the problem, then run the reset and reprogram interface routine on the plugin config page
            Mark
            HS3 Pro 4.2.19.5
              BINGO! The Reset and Reprogram worked!
              Thanks Mark!
