I am very new to HS and I am looking at using HS2 with the new Insteon Hub (2242-522). I am wondering if HS2 & this plugin will work with this new product?
My current setup is all x10 modules and I use mostly extended codes to contro them.
Does your plugin also support x10 comannds (including extended or soft start) or will I need to continue to use my CM11a?
