RegisterStatusChangeCB
This topic is closed.
    3/7/2013 5:19:04 PM Insteon Received ]1 (Office Light On) Go ON
    3/7/2013 5:19:04 PM statusCallBack.vb House Code: ] Device Code 1 Status: 2 Reference # 9377 Device Value: 0
    3/7/2013 5:19:04 PM statusCallBack.vb House Code: ] Device Code 1 Status: 2 Reference # 9377 Device Value: 100
    This is what I get for a Z-wave device
    3/9/2013 10:26:55 AM Device Update Device: Family room Book shelf Status set to ON
    3/9/2013 10:26:55 AM statusCallBack.vb House Code: Q Device Code 32 Status: 2 Reference # 739 Device Value: 100
    How can I get the Insteon plug in to raise the event only once?
    Mats
    what does your declaration for the hs.RegisterStatusChangeCB look like?
    are you registering for status & value changes? how about try it for just value changes using the following EV_TYPE_VALUE_CHANGE
    aso, could you post a detailed log from the plugin showing the plugin log msgs as well as yours.
    Mark
    HS3 Pro 4.2.19.5
      take a look at how I did it:
      http://forums.homeseer.com/showthread.php?t=145834
      --Dan
      Tasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
        I have this in my startup.txt:
         hs.RegisterStatusChangeCB "statusCallBack.vb","checkStatus"
        and my statusCallback.vb looks like this (just for testing at the moment):
        Dim Public ID As String = "statusCallBack.vb"
        Sub checkStatus(ByVal aParm as Object)
         dim stat, hc, dc, hdc,refID, sName as String
        dim dv
        dim svalue
        dim sAction
        'PLACE THIS STATEMENT IN YOUR STARTUP SCRIPT
         ' hs.RegisterStatusChangeCB "statusCallBack.vb","checkStatus"
         hc = aParm(0)
         dc = aParm(1)
         stat = aParm(2)
         refID = aParm(3)
         hdc = hc & dc
          svalue = hs.DeviceValue(hdc)
          hs.writelog(ID,"House Code: " & hc & " Device Code " & dc & " Status: " & stat & " Reference # " & refID & " Device Value: " & svalue)
         End Sub
        How do I get the plugin logs?
        thanks
        Mats
          "plugin logs"?
          do you mean you want to get the status changes from the insteon plugin?
          or something else?
          Mark
          HS3 Pro 4.2.19.5
            Hi Mark,
            No, I was actually refering to the logfiles you asked for earlier:
            thanks
            mats
              well i don't need them now, but for reference:
              the plugin writes to the standard hs log found in \homeseer\logs
              the detail is based on the config setting
              pluing error reports are written to "homeseer\config\insteon error report.log" files
              Mark
              HS3 Pro 4.2.19.5
