Background
I'm experiencing frequent power failures; all of my computer system and peripherals are on UPS, except of course for the Insteon hub. When power is restored to the hub, local switch actions are not picked up by the plug-in and HS initiated commands fail to transmit.
I'm assuming the IP communication is broken between the plug-in and the hub (hub doesn't recognize the socket previously opened by the plug-in ??).
Eventually, after failing to transmit the last 10 commands, the plug-in attempts to restart the interface, as evidenced by the log:
Questions for Mark
1- I tried to restart the hub interface with the "Reset and Reprogram Interface" Insteon action: that fails; should this have worked? Or does the plug-in use another command to restart the hub?
2- If the plug-in uses another command to restart the hub, could you make that available as an Insteon action?
3- I'm now looking for a trigger to restart the hub immediately after a power failure: any suggestions as to how to achieve this?
Wish list
Could the plug-in restart the hub interface automatically after detecting it lost communication with it, ideally immediately after the break of communication, with a user defined interval between attempts ?
2013-11-19 16:15:00 Insteon Warning! Communications lost. Attempting to restart the port...
2013-11-19 16:15:01 Insteon Attempting to restart the port and Interface...
2013-11-19 16:15:07 Insteon PLM contacted on 192.168.1.15:25105 with an Insteon address of 1E.9E.CF and firmware version 9C
2013-11-19 16:15:07 Insteon Interface successfully restarted.
So, I'm trying to initiate this restart as soon as possible, way before failing 10 commands.2013-11-19 16:15:01 Insteon Attempting to restart the port and Interface...
Questions for Mark
Wish list
