Mark:
I have been using HS2 and your plugin with the 2413S for several years.
I just purchased the new Insteon hub and have it installed and working on my test setup versus my "live" HA setup. I am running Version 2 of your plugin and have several Insteon devices linked and working just fine.
I also have the X10 interface of the hub enabled and can control the few X10 devices I have remaining in my house (I have been migrating to Insteon for about a year now).
My question is: When my "live" HA server sends out an X10 command to one of my X10 devices, should I be able to see that command received on the "test" network using the hub? I can control the same device with the hub that the other HA server is controlling so I am pretty sure I have good communications (low noise) on my AC wiring. I just don't see the X10 commands received on my test network. Should I be able to see those commands? I read thru several threads and saw mention of polling the hub. Is there a polling enable, timer, etc for the hub interface?
I also noticed that if I look at the HS2 Setup/Interfaces menu it shows the Insteon and X10 interfaces enabled and it also shows COM14 in the com port box. On the main configuration page of your plugin, I have the correct IP/Port shown (obviously since it is working). Is that normal?
