So, I have a new computer that I have HS3 on. How do I move all my devices over? I don't see a way to import them from the PLM. Can I move my plugin database over and the do a 're-program' PLM or do I have to go around the house and re-add all 80+ devices?
How to move to HS3?
Copy your hs2 config\insteon.ini to the hs3 config folder
the plugin will rebuild the necessary hs devices. all your links will be preserved.
you will need to rebuild events; no way to migrate thoseMark
HS3 Pro 4.2.19.5
Chadg,
There is no "push a button" way to carry your events over to HS3. You should look into this post for a utility that at least gets you started:
http://board.homeseer.com/showpost.p...04&postcount=1
