I have a 6 button keypad and I use the Top and Bottom buttons to trigger events that turn on/off all lights. I want to start using Buttons A, B, C & D but I can't get them to trigger events via the same method.
This works - triggers and event
Master Bedroom Keypad Button On/Load: Transmits an On Command
This doesn't work - does not triggers and event
Master Bedroom Keypad Button A : Transmits an On Command
I see in the HS3 log that it sees the button transmits an On but the event doesn't trigger.
Any idea how I can get this to work?
P.S. I've set the keypad buttons to always transmit on (not toggle).
Thanks!
-Mike
Thanks!
-Mike
