I am using the Insteon Plugin for Insteon devices only, and use the X10 plugin for X10 devices. However, the Insteon Plugin crashes almost daily on an X10 issue, and creates an error report. Here are the relevant portions. The log is almost 2MB. I can attached the full log if needed.
Insteon Plug-in Error Log Generated 2/2/2014 7:04:04 PM
-----------*Error Message*----------------
Error: Error in X10Event: Conversion from string "" to type 'Integer' is not valid. -- Details System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (String Value)
--- End of inner exception stack trace ---
at HSPI_Insteon.hspiAPI.HSCallback.X10Event(String Codes, String housecode, Int16 command, String extra, String data2) -- 2/2/2014 7:04:04 PM
--------*Initialization Log*--------------
2/2/2014 10:11:31 AM - Host System: () 3.0.0.55
2/2/2014 10:11:31 AM - Plugin: HSPI_Insteon.DLL - v3.0.3.16
2/2/2014 10:11:31 AM - RegisterCallback Completed
2/2/2014 10:11:31 AM - Enter InitIO
2/2/2014 10:11:31 AM - Enter InitPlugin
2/2/2014 10:11:31 AM - Global initialization of plug-in required, starting up.
2/2/2014 10:11:31 AM - Initializing Insteon hardware interface...
2/2/2014 10:11:31 AM - In ProcessRawReceiveThread
2/2/2014 10:11:31 AM - In PLMBuffer_ProcessBufferThread
2/2/2014 10:11:31 AM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
2/2/2014 10:11:31 AM - ..waiting 488ms
2/2/2014 10:11:32 AM - ..Got Interface Response 02 60 13 AC 83 03 15 92 06
2/2/2014 10:11:32 AM - ..Time to send message: 514.1457
2/2/2014 10:11:32 AM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
2/2/2014 10:11:32 AM - ..waiting 495ms
2/2/2014 10:11:32 AM - ..Time to send message: 505.6948
2/2/2014 10:11:32 AM - RF PLM contacted on COM3 with an Insteon address of 13.AC.83 and firmware version 92
2/2/2014 10:11:32 AM - ResourceManager::RequestExclusive for Resource 1
2/2/2014 10:11:32 AM - ResourceManager::RequestExclusive acquired for Resource 1
2/2/2014 10:11:32 AM - Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
2/2/2014 10:11:32 AM - ..waiting 194ms
2/2/2014 10:11:32 AM - ..Got RF PLM Response 02 6B 48 06
2/2/2014 10:11:32 AM - ..Time to send message: 218.3311
2/2/2014 10:11:32 AM - ResourceManager::ReleaseExclusive for Resource 1
2/2/2014 10:11:32 AM - Insteon hardware interface initialized.
2/2/2014 10:11:32 AM - I/O (Insteon Protocol) Interface Initializing...
2/2/2014 10:11:32 AM - In TransmitMessageThread
2/2/2014 10:11:32 AM - Scheduled polling enabled.
2/2/2014 10:11:32 AM - In CreateDevices
2/2/2014 10:11:32 AM - Scheduled polling temporarily stopped.
2/2/2014 10:11:32 AM - Reloading 4 Insteon group information tables...
2/2/2014 10:11:32 AM - Reloading 31 Insteon device information tables...
2/2/2014 10:11:34 AM - Time to load devices from ini: 1.428
2/2/2014 10:11:34 AM - 37 Matching HS device records were found and updated for the Insteon device database.
2/2/2014 10:11:34 AM - 4 Matching HS device records were found and updated for the Insteon group database.
2/2/2014 10:11:35 AM - Scheduled polling resumed.
2/2/2014 10:11:35 AM - Exit CreateDevices
2/2/2014 10:11:35 AM - I/O(Insteon Protocol) Interface Initialized.
2/2/2014 10:11:35 AM - Exit InitPlugin
-----------*Pre-Error Log*----------------
2/2/2014 6:43:27 PM - PLM_ProcessInBuffer received STX 0x52, but the command payload is incomplete, waiting..
[... This line is repeated many times, then there are a lot of messages, which end up with the following...]
2/2/2014 7:03:59 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):07 00
2/2/2014 7:03:59 PM - Processing Received X10 Address: M9
2/2/2014 7:04:00 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):05 80
2/2/2014 7:04:00 PM - Processing Received X10 Command: M Bright
2/2/2014 7:04:00 PM - ***:Error in X10Event: Conversion from string "" to type 'Integer' is not valid. -- Details System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
2/2/2014 7:04:01 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):05 80
2/2/2014 7:04:01 PM - Processing Received X10 Command: M Bright
2/2/2014 7:04:02 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):05 80
2/2/2014 7:04:02 PM - Processing Received X10 Command: M Bright
2/2/2014 7:04:03 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):05 80
2/2/2014 7:04:03 PM - Processing Received X10 Command: M Bright
2/2/2014 7:04:03 PM - Starting Scheduled Polling...
2/2/2014 7:04:03 PM - ..Finished Scheduled Polling for 0 devices.
2/2/2014 7:04:04 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):05 80
2/2/2014 7:04:04 PM - Processing Received X10 Command: M Bright
2/2/2014 7:04:04 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):07 00
2/2/2014 7:04:04 PM - Processing Received X10 Address: M9
2/2/2014 7:04:04 PM - PLM_ProcessInBuffer received STX 0x52 (Raw X10 Rec):04 80
2/2/2014 7:04:04 PM - Processing Received X10 Command: M Dim
2/2/2014 7:04:04 PM - ***:Error in X10Event: Conversion from string "" to type 'Integer' is not valid. -- Details System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
--------*End Pre-Error Log*--------------
