Replace this Device fails with 2457D2 LampLinc
This topic is closed.
try manually linking the new device to the plm before starting the swap routine. put plm into linking mode then put the new device into linking mode. then try the swap again.
the swap routine isn't 100% - too many possible swap combinations so you will need to recreate your links and settings after it finishesMark
HS3 Pro 4.2.19.5
