thanks mark. i read the usb disconnect thread and applied some of that and the plug in reinititialized... but i will switch to yours and delete the HS one. i assume its as simple as that? disable theirs and enable yours?
HS2: problems initializing
Originally posted by gfs View Postthanks mark. i read the usb disconnect thread and applied some of that and the plug in reinititialized... but i will switch to yours and delete the HS one. i assume its as simple as that? disable theirs and enable yours?Mark
HS3 Pro 4.2.19.5
yes, that looks like mine.
but you are confusing me. if you are running HS2, then why are you messing with the other insteon plugin; its hs3 only.Mark
HS3 Pro 4.2.19.5
i am confused myself. i have used that plug in and I thought it was the HS supplied version. maybe its yours. because today I bought yours when i did the disable and reload thru the updater. but it didnt show up as needing to register, just said i was registered. but i got a new license number from HS store.HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
I'm pretty sure you have been using mine. please make sure to post new thread here and not the homeseer insteon forum.Mark
HS3 Pro 4.2.19.5
